Manufacturing Solutions
HX-0500: Introduction to HyperView
Previous topic Next topic Expand/collapse all hidden text
This tutorial contains:
Elements of the graphical user interface (GUI) features of HyperView
Page and window controls
HyperView provides an interactive and easy-to-use environment for the visualization of engineering and result data obtained from finite element analysis (FEA). Deformed, linear static, transient and modal analysis animations can be visualized.
Exercise
In this exercise, you will:
Work with a session file
Develop an understanding of the GUI
Use the page and window controls
hmtoggle_plus1greyFiles
The model files for this tutorial are located in the file mfs-1.zip in the subdirectory \hx\MetalExtrusion. See Accessing Model Files.
To work on this tutorial, it is recommended that you copy this folder to your local hard drive where you store your HyperXtrude data, for example, “C:\Users\HyperXtrude\” on a Windows machine. This will enable you to edit and modify these files without affecting the original data.  In addition, it is best to keep the data on a local disk attached to the machine to improve the I/O performance of the software.
hmtoggle_plus1greyElements of the Graphics Interface
The main elements of the HyperWorks Desktop graphic interface are shown in the image below:
HX_0500_01
Menu Bar
Windows-style pull down menus that allow you to access the HyperView functions and tools are located along the top of the screen.
Graphics Display Area
Models, plots, and animations are displayed in this area. It can be divided into multiple windows.
Toolbar
Panels containing tools associated with HyperView can be accessed using the toolbar buttons. Panels are also accessible from the menu bar.
Panel
Most operations are performed using the panel options.
hmtoggle_plus1greyPage and Window Controls
The following page controls are displayed for all applications and are used to manage pages, change page layouts, and manipulate individual windows.
page_controls_toolbar_12
Button
Function
Behavior
pagePrevious-24 / pageNext-24
Previous page / Next page
Displays the preceding or subsequent page.
pageNew-24 / pageDelete-24
Add page / Delete page
Adds a page to the end of the current session page and makes it the active page.
Deletes the current page and makes the next page the active page.
pageLayoutSingle-24
Window layout
Sets the current page window layout to the icon selected from the drop down menu.
windowExpand-24 / windowReduce-24
Expand/Reduce Windows
Expands the active window to full screen, or reduces the expanded window to normal page layout. When one is selected, the other icon immediately becomes the only available option.
windowSwap-24
Left Only
Displays the Pick Target dialog, and swaps the current window with selected option.
windowSyncOn-24 / windowSyncOff-24
Window Synchronization
Displays the Select Windows to Synchronize dialog. Choose the windows to sync, and then select the Stop Windows Synchronization icon.
hmtoggle_plus1greyStep 1: Load the HyperXtrude Results File
1.In the toolbar, click on the Load Model icon file_icon_2. A panel is drawn.
2.Browse for the file HX_0500_000.h3d and specify it for both the Load model and Load results field.
HX_0500_05
3.Click Apply to load the results file into HyperView.
HX_0500_06
hmtoggle_plus1greyStep 2: Use Page Layout to create a three-window layout
1.Click the Page Window Layout icon pageLayoutSingle-24 in the toolbar and select the three-window layout icon pageLayout3Vertical-24. The border of the left-most window in the three window layout is cyan to indicate it is the active window.
hmtoggle_plus1greyStep 3: Load the results file in windows two and three
1.Make window 2 active by clicking on it.
2.Repeat step 1, clicking on window 3 this time.
hmtoggle_plus1greyStep 4: Display the components
In this step you will:
Display the Profile3D component in window 1
Display the Bearing3D component in window 2
Display the Recess3D component in window 3
1.Make window 1 active.
2.In the Results browser, right-click on Components and select Hide. This will switch off the display of all the components in the model.
HX_0500_07
3.Click on the import_fe_model_iconicon next to Profile3D to switch on the display for only Profile3D.
4.Repeat the above steps for window 2 and window 3 for the components Bearing3D and Recess3D. Press F on the keyboard to fit the model in the active window.
HX_0500_08
hmtoggle_plus1greyStep 5: Add a new page and display Ring3D component
1.Click the Add Page icon pageNew-24 to add a new page.
2.Repeat Step 1.
3.Switch off all the components from the Results browser.
4.Display only Ring3D component.
5.Use the icons previous_page and pageNext-24to navigate between pages
hmtoggle_plus1greyStep 6: Save the session to a session file
1.From the File menu, select Save AS > Session.
HX_0500_09
2.Specify the name as HX_0500 for the MVW file and click Save.
hmtoggle_plus1greyStep 7: Open the session file HX_0500.mvw
1.In HyperView, from the File menu, select Open > Session.
2.Select HX_0500.mvw.
3.Notice the contents of the session. It contains the number of pages and window layouts created in the previous session.
Return to Metal Extrusion Tutorials
