Manufacturing Solutions
Graphical User Interface Features
The HyperForm GUI features menu panels, pull down menus, and macro menus. HyperForm includes user profiles that customize the interface for a particular type of analysis:
RADIOSS One Step
RADIOSS Incremental
LS-DYNA Incremental
Die Module
HyperForm contains several panels that are unique to the currently selected user profiles.
The panels included are:
RADIOSS One Step
Die Module
RADIOSS Incremental
LS-DYNA Incremental
Advanced
Addendum
Components
Advanced
Autotipping
Binder
Contacts
Components
Blankholder
Line Design
Curves
Contacts
Blank shape
Modify Addendum
Drawbeads
Curves
Circle grid
Prep. Geom
Loadcols
Drawbeads
Components
Section Edit
Load Result
Loadcols
Constraints
Materials
Load Result
Drawbeads
Sections
Materials
FLD curves
Tool Build
Sections
FLD plots
Tool Loads
Tool Build
Line mapping
Tool Motion
Tool Loads
Materials
Tool Motion
Part outline
Run analysis
Undercut chk
You can also use any HyperMesh panels that do not appear in the standard HyperForm interface, either from the menu bar or by switching to the HyperMesh user profile.
See Also:
Importing Files
Exporting Files
The User Interface
User Process
Tools
Applications
Setup
Panel Descriptions
