Manufacturing Solutions
Exporting Files
Exporting Files
Exporting Files
The Export tab allows you to export a model to CAD line and surface data or finite element models.
The Custom option allows you to export models using your own custom-built export translator. The Custom option can also be used to export models using a translator provided with the HyperForm installation but which is not directly accessible via the default export menu. To access the Custom option, set the File type: field in the Export tab to Custom.
This allows you to write information from a HyperForm database to many finite element formats.  However, geometry data can only be written in IGES format.
