Manufacturing Solutions
Exporting Geometry
Exporting Geometry
Exporting Geometry
1.From the File menu, click Export...
2.Select the Export Geometry fileExportGeometry-24 icon.
3.From the File type: drop down list, select the type of file you want to export.
4.In the File: field, click the folder icon to browse for the file to export. Once the file is selected, click Open.
5.To set further options, click Export options to expand the Export tab.
6.In the Export: field, select All or Displayed.
If Displayed is selected, only the geometry currently showing in the graphics area will be exported.
7.Enter settings for the fields Units:, Outer loops and Layers.
8.Activate the Prompt before overwrite checkbox if desired.
9.Click Export to apply the settings and export the model.
