Node Based Surface: Delete Surface Node Tab
Use the Delete Surface Node tab to delete the SurfaceNode elements.
Node bases surfaces are displayed by special single node SurfaceNode elements.
There are two options for deletion:
- (a) All
表 1. Button Action Delete Deletes all SurfaceNodes elements from the current surface. - (b) By node
表 2. Button Action Surface nodes Opens the Element Selector panel for you to select SurfaceNodes elements from the graphic area. The corresponding Reset button resets the selected elements. Delete Deletes the selected SurfaceNodes elements from the current surface.
