Analytical Rigid Surface
Use the Analytical Rigid Surface dialog to define the *SURFACE, TYPE = CYLINDER, REVOLUTION or SEGMENTS card.
When you click Create, the Analytical Rigid Surface dialog opens.
Each tab of the Analytical Rigid Surface dialog contains the following buttons:
表 1.
Button Action
Surface color Changes the color of the current surface in the display.
Review Reviews the current surface by highlighting line segments and generated revolute or swept surfaces in white. Right-click on the Review button to clear the review selections.
Close Updates the HyperMesh database with the optional parameters that you specified and closes the Analytical Rigid Surface window.
