Node Based Surface: Define Tab
Use the Define tab to define surfaces with individual nodes and define the surface by specifying a node set.
The layout of the Define tab changes based on your selections.
Individual Nodes
Use the Individual nodes option to define the *SURFACE, TYPE = NODE card by specifying individual node IDs.
In the graphic area, these nodes are displayed by special single node elements with a SurfaceNodes tag.
The Individual nodes option has the following buttons:
Button | Action |
Pick Nodes | Opens the Node Selector panel, from which you can select nodes the graphic area. The selected nodes will be highlighted. The corresponding Reset button resets the selected nodes. |
Add | Adds the selected nodes to the current surface and creates special single-node SurfaceNodes elements for display. The Add button does not check for duplicates and there is no Reject button. |
Node Set
Use the Node set option to define the *SURFACE, TYPE = NODE card for node sets.
Only one node set is allowed in a surface. A combination of node sets and individual nodes in the same *SURFACE data line is not supported.
The Node set: menu contains a list of the existing node sets.
Selecting Node set enables the following:
Button | Action |
Review Set | Reviews the selected node sets by highlighting the nodes in the graphic area. Right-click Review to clear the review selections. |
Create/Edit Set | Opens the Entity Sets panel. When you finish creating/editing the set, click return. The Node Based Surface dialog is updated with the new set appearing in the node set list. |
Area | Select this check box to define the optional cross-sectional
area at each node of the node set selected. 注: The
cross-sectional area data item is only supported for
surfaces defined by node sets.
Update | Adds the selected node set into the current surface. HyperMesh does not create a display for surfaces defined with node sets. |
