Events
Events create motions and forces in the model which make the system move. Most events add additional parts to the model to perform the simulation.
The events described here are designed to work with a full vehicle model that has been built through the MotionView Assembly Wizard. The event should attach to the model automatically when added through the Task Wizard. The event can be used with models built manually, as long as the attachment scheme in the event is strictly followed.
