Static Ride Analysis
The Static Ride analysis is a simulation of both wheels moving up and down, in phase, with the steering wheel held fixed. The chassis is fixed-to-ground. The displacement of the wheel center is prescribed by the user. The suspension moves via a simple control system and a “suspension test rig”. The wheel is constrained at the tire patch location to the suspension test rig using an in-plane joint. Standard suspension requests (caster, camber, toe, etc.) are included as part of the ride analysis and are described here. The front and rear suspension ride analyses are similar.
The Static Ride analysis is designed to work with front and rear half vehicle models that have been built through the MotionView Assembly Wizard. The analysis should attach to the model automatically when added through the Task Wizard. The analysis can be used with models built by hand, as long as the attachment scheme in the analysis is strictly followed.
Figure 1. Front Suspension Static Ride Analysis
Figure 2. Rear Suspension Static Ride Analysis
The analysis begins at Zero displacement (design position).
Time (in seconds)
Action
0 to 2.5
Wheels move from design position to jounce position
2.5 to 5.0
Wheels move from jounce position to design position
5.0 to 7.5
Wheels move from design position to rebound position
7.5 to 10.0
Wheels move from rebound position to design position
10.0
Analysis ends.
Suspension travel is entered on the Static Ride Parameters form in the analysis. Travel is assumed to be symmetric. The suspension displacement follows a simple harmonic function (sin wave) pattern.
A total of forty-seven outputs are calculated, including all of the Suspension Design Factors. Input data for the SDFs are entered on the Vehicle Parameters form in the Static Ride analysis.
How the Analysis Works
The Static Ride analysis is a vertical displacement of the suspension, with the wheels moving in phase. The mechanism to perform this is described below:
  • A Jack body is included in the analysis.
  • The Jack body is constrained to ground with a translational joint, allowing the Jack body to only move in the vertical direction.
  • An Inplane joint constrains the jack to the wheel at the SLR distance entered in the Vehicle Parameters form.
  • The solver variables Left Command Variable and Right Command Variable define the desired displacement of the Jack bodies.
  • The solver variables Left Feedback Variable and Right Feedback Variable measure the distance in the Z direction between the wheel center point on the wheel, and the wheel center point on the ground.
  • Solver differential equations diff left jack and diff right jack are defined as the difference between the Feedback and Command variables. An IF statement and the MODE function is used to turn the solver differential equation on during statics and quasi-statics and set it to zero (turning off the solver differential equation) during the remaining analysis modes (Kinematics, Initial Conditions, Dynamics, and Linear Analysis).
  • A force Jack vertical actuator is defined to be the DIF (value) of the solver differential equation diff left jack using an expression.
    The Jack vertical actuator force moves the suspension through jounce and rebound. The force magnitude is determined by the differential controller value.
Note: The control diff (a simple control system) is used for two reasons:
  1. The control system and test rig mechanism does not add constraints to the suspension. This allows the wheel center compliance matrix to be calculated easily, which is used in the suspension design factor calculations.
  2. A force is applied on the test rig “Jack” to move the wheel center vertical (Z) displacement through a prescribed motion. A control system is required for this type of system
