Design of Experiments and Optimization
All of the MotionView models can be used in either a Design of Experiments (DOE) or Optimization study using the HyperStudy client in HyperWorks.
The vehicle dynamics problem is challenging to optimize because there is not a clear objective to optimize (such as weight). Most engineering teams choose to use DOE studies to understand the effects of changing individual variables on the suspension or vehicle system. The DOE method allows for easy studies and analysis of a wide number of variables. The experiments can be easily set up and run using the existing toolkit in HyperStudy.
