hm_viewup
Rotates the model up about an axis oriented horizontally across the screen.
hm_viewup
HyperMesh Tcl GUI Command
This command allows the user to rotate the model up about an axis oriented horizontally across the screen. The rotation angle is defined using the *setoption rotation_angle command. The base for rotation is defined using the *rotateabout command.
hm_viewup
None.
