hm_gettwoitemtoggle
Returns the current selection number of a two-item toggle menu bar item.
hm_gettwoitemtoggle panel_name toggle_id
HyperMesh Tcl GUI Command
panel_name
The name of the panel from which the two-item toggle is accessed.
target_id
The ID of the two-item toggle to query.
To get a plane definition from a user:
set selected_id [hm_getitemnumber lines "Input Component"]
set toggle_id [hm_getitemowner lines $selected_id]
set current_selected_id [hm_gettwoitemtoggle lines $toggle_id]
   # Handle error
Version History
14.0
