hm_posteeformarkmask
Posts a pop-up for a mark of entities.
hm_posteeformarkmask entity_type mark_id ?title? ?modal? ?disable_create_edit?
HyperMesh Tcl Query Command
entity_type
The type of entity to post the editor for.
entity_id
The ID of the entity to post the dialog for.
title (optional)
Specifies the title of the dialog. The default title is Entity Editor.
modal (optional)
Specifies whether the dialog is modal (1, default) or not (0).
disable_create_edit (optional)
Specifies whether to disable the Create and Edit context menu items (1) or not (0, default).
To display an for the component with ID 2:
hm_posteeforentity comps 2
   # Handle error
Version History
13.0
