hm_viewccw
Rotates the model counter-clockwise about an axis oriented perpendicular to the screen.
hm_viewccw
HyperMesh Tcl GUI Command
This command allows the user to rotate the model counter-clockwise about an axis oriented perpendicular to the screen. The rotation angle is defined using the *setoption rotation_angle command. The base for rotation is defined using the *rotateabout command.
hm_viewccw
None.
