hm_registerredraw
Specifies if markers and shapes should be redrawn when the associated entity is modified.
hm_registerredraw mode
HyperMesh Tcl GUI Command
mode
0 - Do not redraw
1 - Redraw
Examples
To enable redrawing of markers and shapes:
hm_registerredraw 1
   # Handle error
Version History
2019.1
