hm_getint
Get an integer value using a HyperMesh panel.
hm_getint ?caption? ?message? ?default_value?
HyperMesh Tcl GUI Command
This command returns an integer value by providing you with a HyperMesh panel.
?caption?
Optional caption to show when entering the panel.
?message?
Optional string to show in the status bar when entering the panel. caption must be specified to use this option.
?default_value?
Optional default integer to set when entering the panel. message must be specified to use this option.
set count [hm_getint "Count=" "Please specify the count"]
None.
Version History
2017.1 - Added new optional default_value argument.
