hm_edittextcard
Launches the Tk control Card Editor to edit a text control card.
hm_edittextcard entity_id
HyperMesh Tcl GUI Command
This command launches the HyperMesh Tk control Card Editor to allow editing of a specific control card. Use hm_istextcard to determine if a control card can be edited using this command.
entity_id
The ID of the text control card.
To edit control card 100:
hm_edittextcard 100
   # Handle error
