hm_windowtofile
Capture a rectangular area of the screen and save it to a file.
hm_windowtofile x y width height filename
HyperMesh Tcl GUI Command
This command saves to a file the rectangular window area specified by you.
This command is only available and supported on Windows.
x
The upper left window corner x-coordinate. This is relative to the root window.
y
The upper left window corner y-coordinate. This is relative to the root window.
width
The width of the window in pixels.
height
The height of the window in pixels.
filename
The full path and filename of the image to save.
To get the modeling window coordinates and copy the modeling window to a file:
foreach {x y w h} [hm_getgraphicsarea] {}
hm_windowtofile $x $y $w $h c:/graphicsarea.bmp
   # Handle error
Version History
9.0
