hm_viewcw
Rotates the model clockwise about an axis oriented perpendicular to the screen.
hm_viewcw
HyperMesh Tcl GUI Command
This command allows the user to rotate the model clockwise about an axis oriented perpendicular to the screen. The rotation angle is defined using the *setoption rotation_angle command. The base for rotation is defined using the *rotateabout command.
hm_viewcw
None.
