hm_highlightentity
Control the highlighting of a single entity collector.
hm_highlightentity entity_type collector_id highlight
HyperMesh Tcl Query Command
This command is used for changing the highlighting of a single entity, and requires use of *createentitypanel to select that entity.
entity_type
The type of entity to control the highlighting for.
collector_id
The ID of the single entity collector. Usually set to 0.
highlight
The state of the highlighting. Valid values are:
  • l, low or lowlight - set to low (gray) highlighting
  • n, norm or normal - set to normal (no) highlighting
  • h, high or highlight - set to high (white) highlighting
To display a single element in a low state:
*createentitypanel elems "Select one element"
hm_highlightentity elems 0 "low"
if { [ catch {hm_highlightentity...} ] } {
  # Handle error
