hm_getfloat
Get a floating point value using a HyperMesh panel.
hm_getfloat ?caption? ?message? ?default_value?
HyperMesh Tcl GUI Command
This command returns a float value by providing you with a HyperMesh panel.
?caption?
Optional caption to show when entering the panel.
?message?
Optional string to show in the status bar when entering the panel. caption must be specified to use this option.
?default_value?
Optional default float to set when entering the panel. message must be specified to use this option.
set distance [hm_getfloat "Distance=" "Please specify a distance"]
None.
Version History
2017.1 - Added new optional default_value argument.
