hm_callspecialpanel
Displays the specified special panel.
hm_callspecialpanel panel_name
HyperMesh Tcl GUI Command
This command will display the specified special panel.
panel_name
The name of the special panel. Valid names are:
  • card
  • controlcards
  • display
  • global
  • options
  • plotwindow
  • "spherical clipping"
  • trueview
  • vis
To open the Spherical Clipping panel:
hm_callspecialpanel "spherical clipping"
   # Handle error
