*stringtablestore()
Stores an entry into the string lookup table.
*stringtablestore (key, value)
HyperMesh Template Command
key
Assigned to a string lookup table entry and is used by the @stringlookup() function to find stored entries. key can be a data name or a literal string enclosed in double quotes.
value
The value assigned to an entry in the string lookup table and is returned by @stringlookup().
The example below stores the string shells in the string lookup table with a value of 10:
*stringtablestore("shells",10)
The example below saves component names with a value of 1 in the string table:
*components("","")
*format()
*stringtablestore(name,1)
*output()
