*setettypeelemtypereference()
Sets the element configuration corresponding to the ET type specified in the sensor card image.
*setettypeelemtypereference (sensor_card_image_name, config)
HyperMesh Template Command
Sets the element configuration corresponding to the ET type specified in the sensor card image. This is applicable only for ANSYS.
A 32-character string enclosed in double quotes that indicates the card image name of the sensor for which the element configuration applies.
config
The configuration number of the elements in the sensor card image.
*setettypeelemtypereference("SHELL51",60)
*setettypeelemtypereference("CONTAC52",70)
*setettypeelemtypereference("PLANE53",106)
*setettypeelemtypereference("PLANE53",108)
*setettypeelemtypereference("SOLID46",208)
Version History
14.0
