*crosssections()
Starts a crosssections block.
*crosssections (config)
HyperMesh Template Command
This command must be accompanied by a *output() command at the end of the block.
config
An integer that defines the config of entities in the block. If not specified, all entities are considered for the block.
To write out all crosssections with the format:
*crosssections(id,"name")
*crosssections()
  *format()
    *string("*crosssections(")
    *field(integer,id,0)
    *string(",")
    *field(quotedstring,name,0)
    *string(")")
    *end()
*output()
Version History
14.0
