*registerparameterizeddataendstring()
Registers the string to be added after parameter names written in place of parameterized values.
*registerparametrizeddataendstring ("string")
HyperMesh Template Command
string
The string to added after the parameter names.
Examples
In Abaqus, parameter names are written within angular brackets and are registered as:
*registerparametrizeddataappendstring("<")
*registerparametrizeddataendstring(">")
In LS-DYNA, parameter names are preceded by & and are registered as:
*registerparametrizeddataappendstring("&")
Version History
14.0
