*registerparameterizeddataappendstring()
Registers the string to be added before parameter names written in place of parameterized values.
*registerparametrizeddataappendstring ("string")
HyperMesh Template Command
string
The string to be added before the parameter names.
In Abaqus, parameter names are written within angular brackets and are registered as:
*registerparametrizeddataappendstring("<")
*registerparametrizeddataendstring(">")
In LS-DYNA, parameter names are preceded by & and are registered as:
*registerparametrizeddataappendstring("&")
Version History
14.0
