*setformattype()
Sets the export format type for the LS-DYNA profile.
*setformattype (?type?)
HyperMesh Template Command
type
The export format type. Valid values are:
1 - Standard format
2 - Long format
3 - I10 format
When no type is passed, the export will be based on the import deck. For instance, when importing a long format deck, by default the export will happen in long format.
To set the export format to long:
*setformattype(2)
Version History
2020
