*encryptions()
Starts an encryptions block.
*encryptions (config)
HyperMesh Template Command
This command must be accompanied by an *output() command at the end of the block
config
An integer that defines the config of entities in the block. If not specified, all entities are considered for the block.
To write out all encryptions with the format:
*encryptions(id,"name")
*encryptions()
  *format()
    *string("*encryptions(")
    *field(integer,id,0)
    *string(",")
    *field(quotedstring,name,0)
    *string(")")
    *end()
*output()
Version History
14.0
