Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
The HyperMesh Card Image panel is used to define solver specific data and review card information. The format of the cards and
the menus in the panel are defined in the export template, using HyperMesh Card Preview Commands.
This command, used in feoutput and summary templates, returns an internal ID based on the pool number and solver ID of
an entity. This command needs to be used in conjunction with the command @getentityvalue(), which returns the solver ID. You must know the pool number corresponding to an entity type of attribute.
@getinternalid()
This command, used in feoutput and summary templates, returns an internal ID based on the pool number and solver ID of an entity. This command needs to be used in conjunction with the command @getentityvalue(), which returns the solver ID. You must know the pool number corresponding to an entity type of attribute.
@getnewid()
Returns the next valid ID by checking IDs of other entities.
@getsolverid()
Returns solver ID based on entity type and internal ID of an entity. This needs to be used in feoutput and summary templates.
@keywordrenumber()
Returns 1 if RENUMBER is passed with the queried keyword via *feoutputwithdata.
@loadexistinmergedloadloadsteptable()
Returns 1 if the load exists in the table containing merged loads for a loadstep created by *createmergedloadloadsteptable().
