@vectorlookupnotkey()
Retrieves a value stored in a vector lookup table.
@vectorlookupnotkey (key,x comp,y comp,z comp)
HyperMesh Template Function
key
Used to compare the keys found in the lookup table entries.
The components of the vector that is used to compare the vectors found in the lookup table entries.
If the input vector matches the vector in the lookup table and the keys do not match, this function returns the value stored in the lookup table. When looking for a match between vectors, the tolerance set by *vectortablereset() is used. If no match is found, this function returns 0.
None.
