@rangeend()
Returns the ending range of a range of numbers.
@rangeend (range)
HyperMesh Template Function
range
The range number, starting at 1.
*elements(104,0,"","")
  *format()
    *rangeadd(id)
  *after()
    *counterset(counter1,1)
    *loopif([counter1 <= @rangecount()])
      *string("start of range = ")
      *field(integer,[@rangestart(counter1)],0)
      *end()
      *string("end of range = ")
      *field(integer,[@rangeend(counter1)],0)
      *end()
      *counterinc(counter1)
    *endloop()
    *rangereset()
*output()
Use *rangeadd() to add numbers to a list. Once all numbers have been added, @rangecount() returns how many ranges, such as 1-5, 10-20, are in the list. Use the functions @rangestart() and @rangeend() to get the actual ranges.
