@getcelltriplevalue()
Returns the values of a triple cell in a table.
@getcelltriplevalue (row_index, column_index, triple_index)
HyperMesh Template Function
This function returns the values of a triple cell in a table. This can only be used inside of a *tables() block.
row_index
The index of the row in the table, starting from 0.
column_index
The index of the column in the table, starting from 0.
triple_index
The index of the triple value. Valid values are 0-2.
*tables()
    *format()
        *counterset(counter1,0)
        *variableset(variable1,columns)
        *loopif([counter1 < variable1])
            *counterset(counter2,0)
            *variableset(variable2,[@gettablecolumnsize(id,counter1)])
            *loopif([counter2 < variable3])
                *variableset(variable3,[@getcelltype(counter2,counter1)])
                *if([variable3 == 7])
                    *field(real,[@getcelltriplevalue(counter2,counter1,0)],0)
                    *string(" ")
                    *field(real,[@getcelltriplevalue(counter2,counter1,1)],0)
                    *string(" ")
                    *field(real,[@getcelltriplevalue(counter2,counter1,2)],0)
                    *end()
                *endif()
                *counterinc(counter2)
            *endloop()
            *counterinc(counter1)
        *endloop()
*output()
Version History
11.0
