@stringsplit()
Splits the given string using the given continuation character.
@stringsplit (string,continuation_character)
HyperMesh Template Function
Splits the given string using the given continuation character. This is used in conjunction with the *field, *fieldleft or *fieldright commands.
string
The string to split.
The character to use on the continuation line. If set to blank, no continuation character will be used.
To split the string contained in the $eigvfile variable into a group of 60 characters, using no continuation character:
*field(string,[@stringsplit($eigvfile,)],60)
To split the string contained in the $eigvfile variable into a group of 60 characters, using + as the continuation character:
*field(string,[@stringsplit($eigvfile,+)],60)
None.
Version History
11.0.101
