@dofs()
Extracts individual degrees of freedom from an integer and returns the status.
@dofs (dof, position)
HyperMesh Template Function
dof
Generally an integer beam end release code that returns 1 or 0 (on or off) if the integer in position is contained within the dof field.
position
@dofs(123,1) = 1, @dofs(456,1) = 0
