@getattributearrayvalue()
Retrieves the value of a 1D array attribute attached to a specific entity.
@getattributearrayvalue (entity type, entity id, attribute, index)
HyperMesh Template Function
entity type
The type of entity, such as sets, elements, or nodes, to which entity id refers.
entity id
The ID of the entity from which you want to get information.
attribute
The name of the attribute (must start with '$').
index
The index into the array (starting at 1).
