@getattributearrayvaluebyinternalid2()
Returns the value (active ID) of a 1D array attribute attached to an entity.
@getattributearrayvaluebyinternalid2 (entity_type, id, attribute, index)
HyperMesh Template Function
Returns the internal ID of a 1D array attribute attached to an entity.
entity_type
The type of entity to query.
id
The internal ID of the entity to query.
attribute
The name of the solver attribute array, starting with $.
index
The index into the array to query, starting with 1.
*variableset(variable2,[@getattributearrayvaluebyinternalid2(loadcols,variable20,$DSLoad_Groups_Name,counter5)])
Version History
2017.1
