@gettablecolumnlabel()
Returns the label of a column in a table.
@gettablecolumnlabel (table_id, column_index)
HyperMesh Template Function
This function returns the label of a column in a table. This can be used both inside and outside of a *tables() block.
table_id
The ID of the table.
column_index
The index of the column in the table, starting from 0.
*tables()
    *format()
        *counterset(counter1,0)
        *variableset(variable1,columns)
        *loopif([counter1 < variable1])
            *field(string,[@gettablecolumnlabel(id,counter1)],0)
            *counterinc(counter1)
        *endloop()
*output()
Version History
11.0
