@lookup()
Retrieves a value stored in a lookup table.
@lookup (key)
HyperMesh Template Function
key
Used to compare the keys found on the lookup table entries. If key matches one of the keys in the lookup table, the function returns the value associated with that entry. If a matching key is not found, the function returns 0.
