@vectorlookup()
Retrieves a value stored in a vector lookup table.
@vectorlookup (key, x comp, y comp, z comp)
HyperMesh Template Function
key
Used to compare the keys found on the lookup table entries.
The components of the vector that are used to compare the vectors found on the lookup table entries
If both the keys match, and the vectors are within tolerance, then this function returns the value associated with the matching entry. If a match is not found, the function returns 0.
None.
