@stringlookup()
Retrieves a value stored in a string lookup table.
@stringlookup (key)
HyperMesh Template Function
key
Used to compare the keys found in the string lookup table. key can be a data name or a literal string enclosed in double quotes.
The following example looks for the string "shells" in the string lookup table.
*if([@stringlookup("shells")])
 *string("$ shells found") *end()
*endif()
The following example finds components whose names are in the string lookup table:
*components("","")
 *format()
  *if([@stringlookup(name)])
   *field(string,name,32) *end()
  *endif()
*output()
None.
