*assemblies()
Starts an assembly output block. All the assemblies in the HyperMesh database are output according to the user-defined format in this block.
*assemblies (assembly name)
HyperMesh Template Command
assembly name
Used as a key to distinguish between different types of assemblies.
To output the components in an assembly, the *pointerset() command must be used to retrieve the component IDs:
*counterset(counter1,0)
*loopif([counter1 != numberofcomponents])
*pointerset(pointer1,components,counter1)
*field(integer,pointer1.pointervalue,0)
*counterinc(counter1)
*endloop()
Requires an *output() command at the end of the block.
