*deletemassthicknesstable()
Deletes the element mass/thickness table.
*deletemassthicknesstable ()
HyperMesh Template Command
Deletes the element mass/thickness table created by *populatemassthicknesstable().
This command must be inside either a *components() or *elements() block and should be called in the *after() section. It must be preceded by a call to *populatemassthicknesstable().
To write out the mass of every component in the format
id,"name",mass
*components("","")
*before()
*format()
*field(integer,id,0)
*string(",")
*field(quotedstring,name,0)
*string(",")
*field(real,mass,0)
*end()
*after()
*output()
Version History
11.0
