*errormessage()
Displays an error message on the menu bar.
*errormessage (string)
HyperMesh Template Command
string
String to be displayed.
The example below displays an error for each quad4 that has a jacobian less than .7:
*elements(104,0,"","")
  *format()
    *if([jacobian < .7])
      *errormessage("jacobian less than .7")
    *endif()
*output()
Each time *errormessage() is called, it overwrites the last error message. If the right mouse button is pressed while printing an error message, HyperMesh stops processing the template.
