*sortentity()
Changes the order that entities are output in the corresponding *entity() block.
*sortentity (entity_type, order)
HyperMesh Template Command
Currently only supported for the
entity_type
The type of entity to sort.
order
Valid values are:
byid - Ordering is performed based on ID
none - No ordering is performed
To output parameters based on their ID:
*sortentity(parameters,byid)
*parameters()
  *format()
    *string("*parameter(")
    *field(integer,id,0)
    *string(",")
    *field(quotedstring,name,0)
    *string(")")
    *end()
*output()
Version History
2020
