*deletemergedloadloadsteptable()
Deletes the table containing merged loads for a loadstep.
*deletemergedloadloadsteptable ()
HyperMesh Template Command
Deletes the table containing merged loads for a loadstep created by *createmergedloadloadsteptable().
This command must be inside a *loadsteps() block and should be called in the*after() section. It must be preceeded by a call to *createmergedloadloadsteptable().
To write out loadsteps using merged loads:
*loadsteps()
*before()
*format()
*after()
*output()
Version History
11.0.101
