*counterset()
Sets the initial value of the global counter.
*counterset (counter, value)
HyperMesh Template Command
counter
Value from counter1 to counter20 indicating the counter(s) to set to the next parameter.
value
Value of the counter.
Counters can be useful to specify continuation cards on some analysis codes. For an example, see theNastran template file in HyperMesh.
