*modelMOI()
Computes the inertia tensor for the global model and store the results into a table.
*modelMOI (table)
HyperMesh Template Command
Computes the inertia tensor for the global model and store the results into a table. This is valid only for LS-DYNA.
The different values are stored in this order in the table:
  • totalIXX
  • totalIYY
  • totalIZZ
  • totalIXY
  • totalIXZ
  • totalIYZ
This command must be called in the *before() section.
table
A value between 1 and 20 indicating which of the 20 possible tables should be manipulated.
To calculate the MOI values and store them in table 11:
*components("", "")
*before()
*tablenreset(11)
*modelMOI(11)
*format()
*after()
*string("Moment of Inertia for Model (Using Center of Gravity As Center):")
*end()
*string("                                                               --                                      --")
*end()
*string("                                                              |  ")
*fieldright(real, [@nlookup(11,1)], 12)
*string(" ")
*fieldright(real, [@nlookup(11,4)], 12)
*string(" ")
*fieldright(real, [@nlookup(11,5)], 12)
*string("  |")
*end()
*string("                                                              |  ")
*string(" ")
*fieldright(real, [@nlookup(11,2)], 12)
*string(" ")
*fieldright(real, [@nlookup(11,6)], 12)
*string("  |")
*end()
*string("                                                              |  ")
*string(" ")
*string(" ")
*fieldright(real, [@nlookup(11,3)], 12)
*string("  |")
*end()
*string("                                                               --                                      --")
*end()
Version History
14.0.110
