Edit General Bursting Scenario Details
Modify bursting scenario details such as scenario name, description, domain name, OS image, tags, and virtual network details.
  1. Login to Control.
  2. Click the Cloud tab.
  3. Click Bursting from the Infrastructure menu located on the left-hand side of the web page.
  4. Select a bursting scenario by clicking its name.
  5. Click Cloud.
    Tip: Some of the information is also editable via the Customization tab.
  6. Click Edit located in the upper right-hand side of the web page.
  7. Change any of the editable data.
  8. Enter a key-value pair to add a tag to the cloud node and press ENTER.
    The key-value pair must be entered as key:value. The key must be less than 36 characters and the value must be less than 43 characters. The length of both the key + value should be less than 80 characters. Valid values are alphanumeric, dash (-) and an underscore ( _ ).
    Once the tag is added, it will appear within its own bubble.
    Key-Value Tag
    Figure 1. Key-Value Tag
  9. Repeat the previous step to add more tags.
    Additional Tags
    Figure 2. Additional Tags
    Tip: To remove a tag click on the 'x' located within the tag bubble.
  10. Scroll to the top of the web page.
  11. Click Save.
