Node Management
The Node Management page enables you to monitor, filter, add and configure nodes quickly through an easy to use interface.
You can add nodes by using naming patterns, filter to a required set of nodes or resources and perform bulk operations. Since the actions are performed in tabs which are minimized to the bottom of the screen, you can return to your configuration task at any point of your workflow.
